My burner wont read and write windows 7 home premium
goldendragon
5
hi! i'm having this problem lately with my burner it won't write, but when I burn a cd it burns fine. its a (tsstcorp cddvdw ts-L633c) i tried using cyberlink its burn for a while but after verifiying it...it fails and pop-out the dvd and there's no burn mark on the dvd. i also tried using this software nero and magiciso same problem it ejects the dvd. I also tried using different dvd, dvd-r and dvd+r nothings change same problem occurs... i tried uninstalling,update, delete the upper, burn it with the lowest speed, still it won't burn. i'm using window 7 home basic. please help!!
I did that already I uninstall and install it a few times but same problem occur. I also update it and nothings change, ... i don't think my burner is damage because it burns fine in cds... tnx
when i burned it using cyberlink.
Description:
(1) Verify data failed.
(2) The disc may be damaged.
23:31:21, File(cl_DVDData.cpp), Line(210)
-> Begin burning process
Current drive: <E: TSSTcorp CDDVDW TS-L633C SC01>
Current writing speed(x): 8.0
====== Disc Info =======
Disc Type: DVD+R
Disc Status: Blank, Appendable
Num. of Sessions: 1 Num. of Tracks: 1
Book Type: DVD+R
Track Path:
Parallel Track Path
Diameter Length: 120mm Layer Counts: 1
Data Area Start PSN: 196608 End PSN: 2491711 End PSN on Layer 0: 0
End PSN : 120mm Layer Counts: 1
Disc Capacity: 2295104LBs
Free Size: 2295104LBs Used Size: 0LBs
Burn option: w/ buffer underrun protection
Burn option: w/o simulation
Burn option: w/ close disc
Burn option: w/ complete verify disc
FS type: UDF_200
Burn mode: PACKET_INC
23:31:21, file(cl_DVDData.cpp), line(3485)
-> Begin new track: 1
23:31:21, file(cl_DVDData.cpp), line(3516)
-> Write data
Last write LBA: 1877312
23:41:35, file(cl_DVDData.cpp), line(3687)
-> Update 2nd AVDP
23:41:55, file(cl_DVDData.cpp), line(3714)
-> End new track
23:41:55, file(cl_DVDData.cpp), line(3724)
-> Close disc
23:42:53, File(cl_DVDData.cpp), Line(326)
-> Burning Fail, ErrCode: 0xeb020bc5
Error Code : 0xeb020bc5
