Hello,
i have a cadillac seville sts 1998. i was driving then all of a sudden the check coolant light lit then a bit after then my car started to overheat so i pulled over and let it cool down and put more coolant then a lil bit after tht all of the coolant that i put in leaked out and my oil percent went from 74 to 0 and i had a puddle of coolant under my car which felt like greasy water i replaced my radiator but then still had the same problems my dad said its either my water pump or a cracked engine block which do you think it is?
