MDXX Distinguished Jan 17, 2011 1,405 0 19,360 Dec 27, 2013 #1 Its not in the manual. Is silver and has a hole for like something to fit in. Its about the size of the stand off screws. Any ideas? I can post a pic if needed
Solution clutchc Dec 27, 2013 That is just a screwdriver adapter so you can use your Phillips screwdriver to tighten your MB standoffs.
C12Friedman Glorious Jan 25, 2012 8,964 1 46,965 Dec 27, 2013 #2 I'm thinking a pic may be helpful, my Challenger didn't come with anything like that that I can recall Upvote 0 Downvote
MDXX Distinguished Jan 17, 2011 1,405 0 19,360 Dec 27, 2013 #3 C12Friedman : I'm thinking a pic may be helpful, my Challenger didn't come with anything like that that I can recall Upvote 0 Downvote
clutchc Titan Ambassador Apr 22, 2009 43,160 409 131,790 Dec 27, 2013 Solution #4 That is just a screwdriver adapter so you can use your Phillips screwdriver to tighten your MB standoffs. Upvote 0 Downvote Solution
MDXX Distinguished Jan 17, 2011 1,405 0 19,360 Dec 27, 2013 #5 clutchc : That is just a screwdriver adapter so you can use your Phillips screwdriver to tighten your MB standoffs. ... lol i feel like a derp right about now. Thanks mate! Upvote 0 Downvote
clutchc Titan Ambassador Apr 22, 2009 43,160 409 131,790 Dec 28, 2013 #6 Lol. No prob. That can't match some of the lame-brained stuff I've done. Upvote 0 Downvote
