My cd slot wont unlock for me to continue my build
I sincerely apologize for confusing you. It is the part when you insert the optical drive.
I mean there's not much to except to force it out somehow, it shouldn't matter much if you break it, because you probably won't have to put it back anyways, some cases with come with jammed slots.
Thanks but.... How shall thee take it out >:)? Btw did not mean that in a sexual way lol
No I didn't mean to make it sexual. No problem for confusing me 😛. I would just say try to take some pliers and try to pull them out somehow, i would really need to get a feel for the case by having it in front of me, can you explain how you would undo it? Do you squeeze the thing in the middle, then yank? Or..?
oh alright well its pretty straight foward turn it left to unlock and right to lock it but its stuck somehow and wont let me unlock it
i Fixed it!!! yes i used the pliers aand turned it and broke it ill just use regular screws more better and trustable ty anyway for helping!
