If I try to listen to anything on chrome for example YouTube, radio etc... No sound will play through my headphones and on playback devices it shows no noise movement if I disconnect the headphones or change the default to the computer it will start to play again.
If I go onto IE then it will play through headphones with no problems.
Please don’t suggest the following:
Go to "Start".."Control Panel"..."Internet Options"...Click the "Advanced Tab"...scroll down to multimedia and put a check mark in play sounds on websites.
Go to Start -> Run -> and enter Services.msc
Scroll down to "Windows Audio".
Double click and change the startup type to Automatic
Make sure you have the latest Java and Flash installed on your computer
Volume mixer...
