S sandy920 Distinguished Jan 26, 2012 1 0 18,510 Jan 26, 2012 #1 I cannot print in color but the printer works fine with other networked printers. I have checked every setting I know.
Hawkeye22 Glorious Feb 10, 2006 11,442 3 49,065 Jan 26, 2012 #2 Make sure you have the correct printer driver installed. Also, check the default settings and make sure "grayscale printing" isn't turned on. Upvote 0 Downvote
R Raghu_vohra Commendable Feb 16, 2016 5 0 1,510 Feb 16, 2016 #3 Yes your greyscale setting is turn on checked it out, Other Wise you installed the driver is not fully installed. Bhagwant Mann I tell u First uninstalled your first driver then install the new driver hope so your problem solved. Upvote 0 Downvote
