My computer does not recognize removable storage devices
G
Guest
Guest
My computer does not recognize ANY removable storage devices! Not the SD card,not my external hard drive (USB) etc. HELP
d_tale
25
Have you tried to connect these devices to another machine? Does your computer find any non storage devices (i.e. headset, webcam etc?)...
You may need to tell us more details...
Molly Cowand
im having this same problem i cant transfer music from my computer to my phone
Saga Lout
This can depend on the phone. With Android devices, when you connect a USB cable to a PC or laptop, you should see a message confirming taht it's been connected but you then have to accept the USB file transfer facility and when you've done that, you have to OK to accept it again. Connect up and look at the top of the screen for the USB icon then drag that downwards to open the screen where you accept the facility. Only then can you "see" the device on the PC under My Computer.
When you've finished, be careful to make sure you right clicked the device in My Computer then select Eject before unplugging. It's the mobile phone version of "Safely remove hardware". I can't help you with iAnything but that's the process for Android mobiles.
Similar threads
