did you go into the channel manager or channel suite
and select the appropiate input?
if you are using a coaxial screw on cable plug then you want
tuner and add it to the channel list
if it is not the screw on plug let me know what you have
also make sure the viewing software is set to channel 3 or 4 depending on what your comcast cable box is set for (default is channel 3)
also make sure the tv tuner card is properly seated it
very easy for a card during a move to move a little out of the slot
even if it looks like it is in there please remove and reseat it
I also have comcast box and a Hauppage and an a ATI theater pro setup
and this usually works for me
