V villadsoesen Prominent Feb 6, 2018 4 0 510 Feb 6, 2018 #1 I bought the Cooler Master MASTERBOX LITE 5 rgb but it’s fans is killing me with the noise. What do I do?
Solution T T Tyler Paul_1 Feb 6, 2018 Hey, this is a common issue my friend had one time where the fans were running stupidly loud. Try install the software speedfan and look up a tutorial how to use it. This should be quite easy to use even for a new person to the software.
T Tyler Paul_1 Prominent Jul 4, 2017 182 0 760 Feb 6, 2018 Solution #2 Hey, this is a common issue my friend had one time where the fans were running stupidly loud. Try install the software speedfan and look up a tutorial how to use it. This should be quite easy to use even for a new person to the software. Upvote 0 Downvote Solution
Lucky_SLS Glorious Dec 16, 2016 8,396 1,135 45,340 Feb 7, 2018 #3 If you have connected them to ur 4 pin fan header in mobo, u should be able to control them. If you have powered them directly from the psu, it will run at the max speed. Upvote 0 Downvote
