First of all I would really only like to say this once. I'm going to include some rules and parameters and I do not want people arguing with them. I need a workaround for them, I don't care if it's messy, if it's noisy, a headache or expensive. I just want a work around and would be genuinely appreciative of any help.
So my gaming case currently has a 120mm intake fan, a basic CPU heatsink/fan combo, my PSU serves as the only exhaust fan and I have my 2 little fans on my graphics card. Now here come the parameters.
I cannot get a new case. It's complicated but I cannot get a new case.
My current case only has a mounting for a single 120mm fan with grating behind it. There is nowhere else to mount or fix any kind of fan, short of purposefully drilling holes and creating my own grating.
I cannot get a bigger/better CPU cooler, it relates to the case and I can't change the case because of the horrendously long story which I'm not going into. I cannot get a better CPU cooler.
So I want things running cooler and don't have many options due in large to the above. The only obvious first step is taking out the very basic 120mm fan and replacing it with a "better" 120mm fan.
The grating for the fan accommodates the 120mm fan but also has a little bit of vertical grating beneath which I think could theoretically mean I could attach at least 1 very small 40mm fan to support it. I know neither of the options is going to yield massive results but it's all I can do at present.
As far as I can tell I only have 1 port on my motherboard for plugging in a fan. Are there adapters for this sort of thing so I could somehow link up more than 1 fan to the same port?
Assuming there are leads me onto my next question. Can fans simply be fixed, hung inside a case simply for the purposes of creating more airflow whilst not really acting as an intake or exhaust? Could I in theory create my own mountings by simply drilling holes in the side panels or bottom so I could attach a fan to operate as additional intakes/exhausts?
Appreciate any help. I know my problem is really bloody awkward but I can't do anything about it. I would just like a workaround regardless of how insignificant it might seem to others.
