Question My CPU and GPU hits high rite after it boots. Fan runs in 4700rpm.
Hey there,
Have you tried changing the performance profiles in Omen Gaming Hub? This will reduce the power going to the CPU on comfort mode, a balanced mix of CPU power and mid temps on default, and then super hot with high fans speeds, but great performance - in high performance mode. High performance mode simply takes off the PL1/PL2 power limitations and lets the CPU rip at full speed, at the downfall of extreme heat and fan noise.
Try the different settings and see if they make a difference.
