[SOLVED] my cpu cores Temps minimum drop to 0c
Jan 1, 2022
7
hello my friend.
1 month ago I changed my AIO cooler. and after that my cpu cores Temps minimum drop to 0c in HWM.
see this pic
https://ibb.co/vsbCgWH
this happen to all cores randomly
my Setup :
Power 850w rog asus
Z590-F Gaming rog asus
RTX 3070 tuf 8g oc asus
Cori7 11700k
G.SKILL Trident Z RGB DDR4 3200Mhz CL16 Dual RAM 32GB
AIO Cooler PF 360 silversone
SSDD 500g 980 pro m2
2T HDD WD
case Td500 mesh cooler master
OP meant temps, not usage.
Yes, I'm talking about temperatures too.
Uncle Webb, creator of Throttlestop, had provided this info in a thread a couple months back: https://forums.tomshardware.com/threads/why-do-my-cpu-minimum-temps-drop-to-0.3722410/
Initially introduced as a bug that Intel chose not to bother fixing, it's become a feature. 12th gen probably has it too.
When a core, or cores, go to sleep, the voltage going to them is shut off. Can't really read the sensor of a core that's shut off, so it reads as 0C.
Reactions: rezapgh
