My cpu fan in stuck in my mobo-Suggestions?
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
The fan pins are stuck in the motherboard. I've tried unscrewing the motherboard+pinching the ends of the pins with needlenose pliers while simultaneously pulling. 1/4 the four pins are stuck in the mobo, and 2/4 won't go into it. I have an intel i5 cpu.
Presuming it's the stock cpu cooler, have you tried a slot screwdriver on the top of the pins? There's supposed to be a position for getting the pins to snap into place, and a different position for releasing the pins.
Edit: with a little searching, I found this guide that should help you, and the same method would probably work for aftermarket push-pin-mount coolers as well:
http://www.intel.com/support/processors/sb/CS-032036.htm
