My CPU is hitting a max 88 celsius while stress testing, safe to overclock?
If that is your load temp now, no. Absolutely not. In fact, it would be wise to find out why the core temp (?) is so high and try to lower it. 72C is Intel's recommended max temp.
What are you using to put the 100% load on the CPU? What cooler are you using?
88'C is definitely on the hot side of things, and I wouldn't be looking to OC from there.
IIRC, a G3258 won't throttle until you approach 100'C...... but sustained load temps >80'c (or >85'C, depending on who/where you ask), is not a good idea for long term use.
How can I lower it?
I'm using a coolermaster gx 650w bronze
Give us an idea of the rest of the system. The case you're using, average room temp. The little 53W dual core should not get that warm at stock speeds. Unless the cooler is loose, the cooler fan isn't working (or is not up to speed), or the case has extremely poor air flow.
I don't know what the case is, there isn't a name on it. The sides are full of little holes though. Average room temperature maybe 23-26 Celsius? The cooler shouldn't be loose either. The computer is really noisy as well!
Shouldn't be, or isn't? Sometimes those pesky Intel push-pins don't get installed correctly or pop loose.
As to the case, I guess it is a pre-built system? Have you noticed the CPU usage when the system is idle? What is the idle temp?
When I originally said normally its 40-50 degrees, it was the idle temp. When playing a game its not much more. And I checked the PC today and it didn't seem to be loose.
40-50C tells me that even the idle is too warm. My Haswell dual core builds always idle in the low-mid 30Cs. I wonder if there is something running your CPU in the background you don't know about. Malware, virus, mining virus...
Check what the CPU usage is at idle.
Its about 38-43C
Well... that isn't 40-50C. But that is better. Still seems higher like something is using clock cycles. Check CPU usage at idle.
Its using 2-4% according to task manager.
How do I check that? And my uncle actually built this PC, the cooler is a Coolermaster GX 650w Bronze if that helps you at all.
edit: Would 7000 RPM sound crazy? Didn't understand BIOS very well.
Sorry I was doing research on coolers today, and it's just a small Intel stock cooler. I'm not home until Sunday, so I'll check the RPM then. Thank you for the replies!
So I came back after being away for 2 days, now I stress tested it and it went up to 100C 58-65C idle? RPM was around 2900-3169
The fan RPM tells me that the fan isn't the problem. The temp is way to high, tho. Should never get above mid 70Cs at 100% usage if the cooler is doing its job and you are in a normal 20C-26C environment. I would remove the stock cooler and either (1) clean/replace the TIM and properly remount the cooler, or (2) replace the stock cooler with an after-market cooler.
There is another less likely possibility. One core have become defective. Check that one core isn't way higher than the other.
As a final experiment, remove the side panel of the case and lay the case on its side. Run the stress test like that so any heat can escape the case when running. That should eliminate bad air flow inside the case as a problem.
Experiment made no difference. 100C but the RPM was just a little lower. Been thinking of getting a Cryorig H7 and seeing if it would help at all. Also, cores are both just about the same temperature.
