My cpu is running 90 degrees
Tem_
Commendable
Jun 12, 2016
My cpu is running at 90 degrees and I only have chrome open yes my heatsink is on correctly and yes I re applied thermal paste my heatsink is stable on my Mobo so whats wrong?
Specs:
i5-4690
stock cooler
8GB Kingston hyper x blue
MSI Nvidia GTX 960 4G
MSI Z97 PC MATE
Cooler master B500
Either you've used too much paste, or too little (IF this is a reinstall of the stock cooler and you've properly cleaned off the the old TIM and reapplied fresh thermal interface material), or the heatsink is NOT correctly seated, even if you think it is. The only other possibilities are that you have no intake fans bringing cool air into the case for the CPU cooler to use, the CPU fan is not running correctly or your are overclocking, which should not be done on a stock cooler. There are really no other possibilities.
99% of the time when I see a thread exactly like yours, and the OP swears the heatsink is correctly mounted and fully seated, it isn't. Often either one of the pins on the stock cooler is NOT fully pushed down into the...
99% of the time when I see a thread exactly like yours, and the OP swears the heatsink is correctly mounted and fully seated, it isn't. Often either one of the pins on the stock cooler is NOT fully pushed down into the motherboard, one of the fasteners is not fully seated or one or more of the eccentric cam on one of the four corners is not turned correctly to the locked position if it has that style of mounting system, which yours should.
As follows:
https://www.youtube.com/watch?v=5qczGR4KMnY
If you installed, and then removed, the heatsink, at any point, and you didn't clean off the original thermal compound from both the CPU lid and heatsink base using isopropyl alcohol or thermal compound cleaner, then you need to do that. Once that cooler is released from pressure or removed, new compound needs to be applied.
75°C is way too high unless you're running a stress test like Prime95. You should never see 75 degree temps in Chrome. Is that Celcius or Fahrenheit you are using? What are you using to monitor temperatures?
What case are you using and how many case fans are installed? What direction is each fan blowing? Have you tried removing the side panel to see what happens to temps then?
