Hey everyone, I'm getting really worried. While Temp #3-5 is fine, Temp#1 and Temp#6 says my CPU is running at 74°C and 103°C. I know that that's not normal.
I am running it at idle (like not doing anything intensive right now).
1. Can anyone please help me out? Which value should I be looking at because there are so many temp readings.
2. I'm using Open Hardware Monitor, is there a better software out there that you would recommend?
3. What do you think of my temperatures overall? Are they all normal? My GPU is running at 34°C is that good?
