My CPU temps and fan RPM are always high, but it's ice cold inside my case.
polite_semite
I've downloaded several programs to monitor temp and fan speed (SpeedFan, CpuID HWMonitor, etc.) and my temperatures for my CPU hit 60C even durinng simple tasks or games.
When I put my hand inside the case or touch the heat sink of my CPU it doesn't feel any warmer than 10C! Literally cold to the touch. Can I trust the temperature numbers these programs are giving me? Is it possible the heat sink is not even absorbing any heat? Currently the CPU load is 12% and the RPM and temp has shot up to 4500 and 54C.
Motherboard: GIGABYTE GA-990FXA-UD3
Processor: AMD FX-8350 Vishera 8x 4.0GHz
Windows 7 x64
It is a stock fan, I'd gladly upgrade the cooling system if I had to, but I'm not entirely sure it is necessary.
then you could get a evo 212 it if fit in your case that will lower cpu temp a lot also use some mx2 or mx4 as cooling paste they do not need cure time .
Max temp has never gotten above 64C and I never see it above 60C for more than 5-10 seconds.
If you're sure there's no problem, then thank you. I will likely buy something better than a stock cooler soon, but knowing there isn't a problem is reassuring.
I didn't know you were looking for temperatures or I'd have run the program and took the screenshot while I had a game or install going. It does idle at good temps, but the fact that it reaches 60C so easily is what worries me.
