Question My CPU values shows crazy values please help
Nov 3, 2021
I have nitro 5 i5 9th gen gtx 1650 version. Suddenly my CPU values is throttlestop showing crazy values such as turbo max 245 and voltage 0.3799 and turbo ration limits 172 .pleas help me
uWebb429
Notable
May 22, 2020
313
109
990
57
Are you using Windows 11? You need to turn off the virtualization features so ThrottleStop can read and write to the CPU registers.
Disable Virtual Machine Platform and Hyper-V and ThrottleStop should work correctly. Delete the ThrottleStop.INI configuration file after you disable these Windows features and reboot. Post some screenshots if you are still having problems. The default turbo ratio limits, voltages and reported DDR speed can only be reported correctly with virtualization disabled.
If you need to run WSL2, you can no longer use ThrottleStop to undervolt your CPU. This used to be possible in Windows 10 but this is not possible in Windows 11.
Nov 3, 2021
Yeah I was using Windows 11 and I also disable the features.It solved the issue .Thank you very much 👍
