. Amd x4 860k r7 360 windows 7 the back and white issue has stopped but now I'm getting horrible black bars around the whole game screen and it will only go away at 1080p
that's because the resolution doesn't fill the screen. when you increase to 1080p, thats your monitors native resolution, and thus it fills the whole screen. Perfectly normal. as to the black and white problem thats solved, correct?
I have fixed it it was a driver issue I had to update but my software for and says there was no updates!
