My current Pc Build
arandomhippo
4
I would like help on my pc build. I have questions about my fps bouncing all over the place and wondering if i should upgrade my motherboard and get a better gpu to share the load.
CPU: AMD FX 6300
Motherboard: Gigabyte GA-990FXA-UD3 ATX AM3+
GPU: Gigabyte GeForce GTX 750 Ti 2GB WINDFORCE
RAM: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1333
HD: 500GB WD 7200 RPM
i have updated all the drivers on the graphics card. I recently downloaded a antivirus software that has a gaming mode built in but haven't tried it yet. is there any software i should look for or a way to test out which software would be causing this?
I also was looking to change it to an intel i5 due to hearing that for gaming the intel processors are sometimes better. Is this true?
In a lot of cases, Intel is better than AMD for gaming by quite a margin. You'd have to replace your motherboard with an LGA1150 socket motherboard in order to switch to an Intel i5 processor ofcourse.
