My current system - better to upgrade CPU or GPU for better game performance?
Dec 11, 2018
Assassins Creed Odyssey is bench marked at 53 fps, and is sluggish running on:
Core i5-3570 on Asus LGA 1155 Z77 / 980 ti / 27" 144hz @ 2560 x 1440.
Where is my best option to upgrade: CPU or GPU for better performance, without having to build an entirely new machine.
WildCard999
Herald
Open world games benefit from a strong CPU, without having to change the MB or RAM I'd go with the 3770K and decent cooling if you can find one used for a good price. Your current 980 ti is still a really good GPU for 1440P so there's no reason to change it.
Oct 5, 2018
515
59
I’d suggest upgrading your CPU. your GPU is basically equivalent of the 1070, which is pretty high performance. I’d suggest a ryzen 5 2600 (which would require a new motherboard) or perhaps an i5-9600k. Depends on your budget.
WildCard999
Herald
Dec 11, 2018
based on the responses, the simplest solution is the i7-3770K as it fits my 1155 socket, on sale for $428 (newegg), and will provide about 25% CPU increase.
(i was not wanting to game at 144 fps, but run the monitor at 144hz)
WildCard999
Herald
Way too expensive! Buy used for much cheaper!
mgallo848
Commendable
Apr 4, 2018
1,551
35
1,790
149
DO NOT BUY IT FROM NEW EGG. WAAAY OVERPRICED. You could get a whole new CPU, motherboard and DDR4 memory for that price.
I would buy one from Ebay instead. Just be careful about buying any coming from China.
WildCard999
Herald
Even if you do find a 3770K for under $200 you might just be better off getting a newer platform for like $100 more. The 2600 easily outperforms the 3570 and even the 3770K in multi-thread apps.
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor ($159.99 @ Amazon)
Motherboard: ASRock - B450 Pro4 ATX AM4 Motherboard ($59.99 @ Newegg)
Memory: Team - Vulcan 8 GB (2 x 4 GB) DDR4-3000 Memory ($60.98 @ Newegg Business)
Total: $280.96
Generated by PCPartPicker 2018-12-11 12:06 EST-0500
The only downside to going this route is that you'll need to reinstall Windows & drivers.
