My Dell laptop 's fan makes a high pitched noise, what shall I do ?
knowledge2121
909
9
18,995
Hello everyone, I have an E6440 with i7-4712MQ...The fan which is connected to the heatsink makes a high-pitched noise sometime(I don't see a pattern) and I want to replace it(Should I?) Is it the fan's fault or is it the CPU ?
If it is the fan, should I replace the heatsink or should I replace only the fan ? If I should replace the fan, which fan is recommended ?
