MY dell latitude laptop power button is on but it's not coming up. No display. I have tried to remove the battery and Press's
Jan 27, 2019
The power button light is on. But the laptop not coming up. It's a dell latitude. I have tried to disconnect the power cable and remove the battery still doing the same thing
Try this...
1. Turn the laptop off (not sleep or hibernate but off).
2. Connect an external monitor to the laptop.
3. Turn on the external monitor.
4. Turn on the laptop.
NOTE: You may have to press an "external monitor" button. Could be the f4 button or a button with two monitors on it, for the external monitor to work.
If you can see fine on the external monitor, then your attached display, or the ribbon cable that connects it, are your problem.
If you can't see on the external monitor at all, or the problem occurs on the external monitor as well, then it is probably the graphics card/GPU that is the problem, which may require the motherboard be replaced.
You may also want to try hitting CTRL + SHIFT + WIN + B to try and reset your graphics driver as another possible fix.
