[SOLVED] my desktop audio not working and all i hear static noise
Dec 8, 2021
4
2 months ago my pc was working fine then my gbu borke after i got new gbu evreything start working fine again but there was no sound only static noise coming out , i checked another 2 headset and the same , updated all drivers , rebooted the pc . still the same issue , please someone help me
Try plugging in to both the front and back jacks to see if either of them work.
Also, some GPUs install an audio passthrough device so you can send audio out an HDMI/DP cable. Make sure you are selecting your actual system sound card and not this device in audio properties.
Dec 8, 2021
4
i tired both front and back and same result ,and i checked im using my system sound card
