Question My display got messed up help
ChaChaRealSmooth
Commendable
May 27, 2019
9
I booted up Action! Mirillis then my display screen started glitching into blackness. then when it finally started working after crashing for 5 minutes my display resolution got lower and the brightness is on full and i cant change any display settings whatsoever they are all grayed out.
I also found that my intel display has error code 43 and i dont know what to do
the laptop is heating up and my display is all messed up
I turned the laptop on and off and noting changed
please help me
my graphics card is AMD R5 M335
<Moderator edit for language>
hang-the-9
Is the laptop in warranty? If it is, first contact the vendor support.
If it's out of warranty, and the system gets hotter than it used to, you would need to take it apart, clean it out and apply new thermal paste to the heatsinks, see if that makes it run better.
