Corsair vengeance ddr5 2x16 5600What is the make/model of your memory?
Try removing the 1050 ti and using the on-board video (be sure to connect your display to one of the video ports attached to your motherboard). Any difference?
[/QUOTE/]
If truly missing, that could be an issue. Could you see the remnants of the pin itself?There is one missing pin. It’s right near the center. It’s on the lower half of where the socket is cut in half horizontal right towards the middle.
Yayyyy. At least Amazon does replacements.Sounds like a new motherboard is in your future.
Also i did some oppisies while assembling.Sounds like a new motherboard is in your future.
Physical damage is generally not covered, but you can certainly try it.Yayyyy. At least Amazon does replacements.
It should be okay.I can’t tell if you’re saying my cpu is good or bad. I’m having a small heart attack
