Question My Ethernet won’t show up or work
Oct 17, 2019
So I just built my new pc (went from a fx6300 with some 970A gigabyte mobo to a Asrock b450 pro-4 Ryzen 2700x) and when I booted into windows my ethernet didn’t work or show up I’ve tried all I could but I’m not sure
Oct 17, 2019
Did you reinstall windows or just swapped your drive over? If you swapped your drive over you may need a driver.
I swapped drivers, and what driver should I install also when I plug it in no light shows and in my device manager it doesn’t show up
kanewolf
A motherboard swap, usually means a clean Windows install. You will be chasing ghost problems like this until you do a clean OS install.
