My External Hard Drive Won't Work
Borg__
100
I've been using a Seagate Hard Drive. When i plug it in it shows nothing, but when i unplug it a message pops up and tells that i need to format my disk. The question is how im gonna format my disk if that message pops up only when i unplug the USB? Please reply asap.
You can attach it to another computer with a different USB cable.
If the drive is not recognized by Disk Management, I doubt you will be able to access it with software tools.
If the drive is under warranty, you can contact the place you got it from and eventually RMA it.
Cheers,
D_Know_WD :)
Hi there Borg__,
If you have some data stored on it, you can see if you can retrieve it first: https://www.lifewire.com/free-data-recovery-software-tools-2622893
If you don't have any, you can go to Disk Management as SR-71 Blackbird suggested and perform the required actions. (initialization, format, etc.)
It would be a really nice idea to check the drive's health status out. You can use some of these: http://www.tomshardware.co.uk/forum/282651-32-best-diagnostic-testing-utility
Cheers,
D_Know_WD :)
The problem is it doesn't appears in the computer neither in the disk management
Cheers,
D_Know_WD :)
