Question My fans do not work so I am running a fan from walmart on my tower....CPUID results posted
Mar 21, 2020
7
Hi,
My fans do not work on computer anymore and I am using a regular fan I bought from walmart to blow air into the case of the computer. Here is my CPUID results, but I do not know how to read them. Does anything look really bad? Please help!!! What do I need to do? Do I need to order something online like from newegg.com to replace to fix these problems?
Here is what it says:
CPUID HWMonitorPro Report
Binaries
HWMonitorPro version 1.4.1.0
Monitoring
Mainboard Model GA-78LMT-USB3 (0x0000035B - 0x9521BE73)
LPCIO
LPCIO Vendor ITE
LPCIO Model IT8728
LPCIO Vendor ID 0x90
LPCIO Chip ID 0x8728
LPCIO Revision ID 0x1
Config Mode I/O address 0x2E
Config Mode LDN 0x4
Config Mode registers
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00
10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
20 87 28 01 00 00 01 02 10 00 80 00 48 01 00 00 00
30 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
60 02 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 02 00 00 04 04 00 00 00 00 00 00 00 00 00 00
Register space LPC, base address = 0x0228
Hardware Monitors
Hardware monitor ITE IT8728
Voltage 0 1.04 Volts [0x57] (CPU VCORE)
Voltage 1 1.49 Volts [0x7C] (DRAM)
Voltage 2 4.95 Volts [0xA5] (+5V)
Voltage 3 9.79 Volts [0x88] (+12V)
Voltage 7 3.31 Volts [0x8A] (+3.3V)
Temperature 0 39 degC (102 degF) [0x27] (TMPIN0)
Temperature 1 88 degC (190 degF) [0x58] (TMPIN1)
Temperature 2 94 degC (201 degF) [0x5E] (TMPIN2)
Fan PWM 0 99 pc [0x7F] (FANPWM0)
Fan PWM 1 0 pc [0x0] (FANPWM1)
Fan PWM 2 0 pc [0x0] (FANPWM2)
00 11 10 00 00 FF FF 00 37 FF 87 48 0F 07 FF FF FF
10 FF FF FF 76 D7 7F 80 82 FF FF FF FF FF FF FF FF
20 57 7C A5 88 A2 B9 B9 8A 86 27 58 5E B9 33 3F 3F
30 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00 FF 00
40 7F 7F 7F 7F 7F 7F 5F 40 AD 6A D4 00 FF FF FF FF
50 FF CE 7F 7F 7F C0 FD FD 90 00 3E 12 60 00 00 00
60 00 14 41 4E 20 03 0F FF 00 14 41 46 20 03 0F FF
70 00 14 41 40 20 03 0F FF FF FF FF FF FF FF FF FF
80 00 00 00 00 00 00 00 00 00 00 00 00 00 63 00 0C
90 FF 00 00 00 FF 00 00 00 42 99 00 00 01 94 F2 5E
A0 4C 6C 6C 6C 6C 6C 6C FF FF FF FF FF FF FF FF FF
B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Hardware monitor Hardware monitor ID=0xFFFFFFFF
Hardware monitor D3D
Hardware monitor NVIDIA NVAPI
Voltage 0 0.98 Volts [0x3CF] (GPU)
Temperature 0 47 degC (116 degF) [0x2F] (GPU)
Fan PWM 0 30 pc [0x1E] (FANPWMIN0)
Clock Speed 0 135.00 MHz [0x87] (Graphics)
Clock Speed 1 405.00 MHz [0x195] (Memory)
Clock Speed 2 n.a. (Processor)
Processors
Number of sockets 1
Number of threads 4
APICs
Socket 0
-- Core 0 (ID 0)
-- Thread 0 0
-- Core 1 (ID 1)
-- Thread 1 1
-- Core 2 (ID 3)
-- Thread 2 3
-- Core 3 (ID 2)
-- Thread 3 2
Timers
ACPI timer 3.580 MHz
Perf timer 10.000 MHz
Sys timer 1.000 KHz
Processors Information
Socket 1 ID = 0
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Manufacturer AuthenticAMD
Name AMD FX-4130
Codename Zambezi
Specification AMD FX(tm)-4130 Quad-Core Processor
Package Socket AM3+ (942)
CPUID F.1.2
Extended CPUID 15.1
Core Stepping OR-B2
Technology 32 nm
TDP Limit 125.2 Watts
Core Speed 1808.0 MHz
Multiplier x Bus Speed 9.0 x 200.9 MHz
Base frequency (cores) 200.9 MHz
Base frequency (ext.) 200.9 MHz
Rated Bus speed 2209.7 MHz
Stock frequency 3800 MHz
Instructions sets MMX (+), SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, SSE4A, x86-64, AMD-V, AES, AVX, XOP, FMA4
Microcode Revision 0x600063E
L1 Data cache 4 x 16 KBytes, 4-way set associative, 64-byte line size
L1 Instruction cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 2 x 2048 KBytes, 16-way set associative, 64-byte line size
L3 cache 4 MBytes, 32-way set associative, 64-byte line size
Max CPUID level 0000000Dh
Max CPUID ext. level 8000001Eh
Cache descriptor Level 1, D, 16 KB, 1 thread(s)
Cache descriptor Level 1, I, 64 KB, 2 thread(s)
Cache descriptor Level 2, U, 2 MB, 2 thread(s)
Cache descriptor Level 3, U, 4 MB, 4 thread(s)
FID/VID Control yes
Min FID 7.0x
# of P-States 7
P-State FID 0x17 - VID 0x0B - IDD 21 (19.50x - 1.412 V)
P-State FID 0x16 - VID 0x0B - IDD 21 (19.00x - 1.412 V)
P-State FID 0x15 - VID 0x0C - IDD 15 (18.50x - 1.400 V)
P-State FID 0x12 - VID 0x12 - IDD 13 (17.00x - 1.325 V)
P-State FID 0xA - VID 0x1E - IDD 10 (13.00x - 1.175 V)
P-State FID 0x2 - VID 0x28 - IDD 7 (9.00x - 1.050 V)
P-State FID 0x10C - VID 0x31 - IDD 5 (7.00x - 0.937 V)
PStateReg 0x800001D5-0x00001617
PStateReg 0x800001D5-0x00001616
PStateReg 0x8000019A-0x00001815
PStateReg 0x80000184-0x00002412
PStateReg 0x80000165-0x00003C0A
PStateReg 0x80000144-0x00005002
PStateReg 0x80000136-0x0000624C
PStateReg 0x00000000-0x00000000
Package Type 0x1
Model 00
String 1 0x0
String 2 0x0
Page 0x0
Base TDP 12 Watts
Boosted P-States 1
Max non-turbo ratio 19.00x
Max turbo ratio 19.50x
Attached device PCI device at bus 0, device 24, function 0
100 00000000 00000000 00000000 00000000
110 00000000 00000000 00000000 00000000
120 00000000 00000000 00000000 00000000
130 000000C1 00000000 00000000 00000000
140 00000000 00000000 00000000 00000000
150 00073100 00000000 00000000 00000000
160 00000000 00000000 00000000 0066E066
170 00000109 00000000 00000000 00000000
180 00000000 00000000 00000000 00000000
190 00000000 00000000 00000000 00000000
1A0 80000003 00000000 00000000 00000000
1B0 00000000 00000000 00000000 00000000
1C0 00000000 00000000 00000000 00000000
1D0 00000000 00000000 00000000 0000000E
1E0 00000000 00000000 00000000 00000000
1F0 00000000 00000000 00000000 00000000
Attached device PCI device at bus 0, device 24, function 1
120 00000000 00000045 00000000 00000000
130 00000000 00000000 00000000 00000000
150 00000000 00000000 00000000 00000000
160 00000000 00000000 00000000 00000000
170 00000000 00000000 00000000 00000000
1A0 00000000 00000000 00000000 00000000
1D0 00000000 00000000 00000000 00000000
Attached device PCI device at bus 0, device 24, function 2
100 00000000 0000677B 00000000 00000000
110 00000503 00000000 044CA424 0CE00F41
120 00BB71C0 00000000 00000000 00000000
130 91B9DB32 F273D343 963A3B34 11BB1D05
180 00000000 00000004 3F000000 00000000
190 08010000 00084000 8D0FE003 00002208
1A0 001F0202 00000000 10000000 00000000
1B0 0FC39101 480F7D26 00000000 00000000
Attached device PCI device at bus 0, device 24, function 3
140 00A11755 00000055 0000C12A 00000000
160 C0000000 00000000 C0000000 00000000
170 C0000000 00000000 00000000 00000009
180 017003E3 00000000 08000210 00000008
190 00000000 00000000 00780400 00000000
1A0 00034184 00000000 00000000 00000000
1B0 1166E326 00000000 08141000 00000000
1C0 00000000 0001FCFC 00000000 00000100
1D0 00000000 00000000 002B170F 00000000
1E0 00000000 80001387 00000011 00000010
1F0 00080000 00000000 00000000 0000074F
Attached device PCI device at bus 0, device 24, function 4
100 00000000 00000321 00000000 00CE0177
110 000FE001 00000000 0107000B 00000000
120 00000000 00000000 00000500 00000000
140 11660AFA 000003CF 27AF6D3C 0000079E
150 00000B77 00EBEBEB 00000000 00000085
160 00600F12 00000001 00000000 00000277
180 E000530F 00001005 00000000 00000000
1A0 0000001F 00000000 00000000 00000000
1B0 00000000 00000000 0028019F 00000000
1C0 00000184 00000110 00000A40 00000090
1D0 00080000 0000FFFF 00000000 00000000
1E0 0BAA1617 0BAA1616 0B341815 0B082412
1F0 0ACA3C0A 0A885002 0A6C624C 00000000
Attached device PCI device at bus 0, device 24, function 5
120 00001111 00000000 00009131 00000000
160 0000600D 00000000 00000000 00000000
170 00000408 00018030 00000000 00000000
190 2233457A 0000000B 00202020 00000000
Temperature 0 78 degC (172 degF) (Package)
Temperature 1 78 degC (172 degF) (Cores)
Power 00 51.90 W (Package)
Clock Speed 0 1807.96 MHz (Core #0)
Clock Speed 1 3816.80 MHz (Core #1)
Clock Speed 2 3816.80 MHz (Core #2)
Clock Speed 3 3816.80 MHz (Core #3)
Core 0 max ratio 19.5 (effective 19.5)
Core 1 max ratio 19.5 (effective 19.5)
Core 2 max ratio 19.5 (effective 19.5)
Core 3 max ratio 19.5 (effective 19.5)
Thread dumps
CPU Thread 0
APIC ID 0
Topology Processor ID 0, Core ID 0, Thread ID 0
CPUID
0x00000000 0x0000000D 0x68747541 0x444D4163 0x69746E65
0x00000001 0x00600F12 0x00040800 0x1E98220B 0x178BFBFF
0x00000002 0x00000000 0x00000000 0x00000000 0x00000000
0x00000003 0x00000000 0x00000000 0x00000000 0x00000000
0x00000004 0x00000000 0x00000000 0x00000000 0x00000000
0x00000005 0x00000040 0x00000040 0x00000003 0x00000000
0x00000006 0x00000000 0x00000000 0x00000001 0x00000000
0x00000007 0x00000000 0x00000000 0x00000000 0x00000000
0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000A 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000007 0x00000340 0x000003C0 0x40000000
0x0000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x0000000D 0x00000100 0x00000240 0x00000000 0x00000000
0x80000000 0x8000001E 0x68747541 0x444D4163 0x69746E65
0x80000001 0x00600F12 0x10000000 0x01C93FFF 0x2FD3FBFF
0x80000002 0x20444D41 0x74285846 0x342D296D 0x20303331
0x80000003 0x64617551 0x726F432D 0x72502065 0x7365636F
0x80000004 0x20726F73 0x20202020 0x20202020 0x00202020
0x80000005 0xFF20FF18 0xFF20FF30 0x10040140 0x40020140
0x80000006 0x64000000 0x64004200 0x08008140 0x0020A140
0x80000007 0x00000000 0x00000000 0x00000000 0x000003D9
0x80000008 0x00003030 0x00001000 0x00004003 0x00000000
0x80000009 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000A 0x00000001 0x00010000 0x00000000 0x000014FF
0x8000000B 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000C 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000D 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000E 0x00000000 0x00000000 0x00000000 0x00000000
0x8000000F 0x00000000 0x00000000 0x00000000 0x00000000
0x80000010 0x00000000 0x00000000 0x00000000 0x00000000
0x80000011 0x00000000 0x00000000 0x00000000 0x00000000
0x80000012 0x00000000 0x00000000 0x00000000 0x00000000
0x80000013 0x00000000 0x00000000 0x00000000 0x00000000
0x80000014 0x00000000 0x00000000 0x00000000 0x00000000
0x80000015 0x00000000 0x00000000 0x00000000 0x00000000
0x80000016 0x00000000 0x00000000 0x00000000 0x00000000
0x80000017 0x00000000 0x00000000 0x00000000 0x00000000
0x80000018 0x00000000 0x00000000 0x00000000 0x00000000
0x80000019 0xF020F018 0x64000000 0x00000000 0x00000000
0x8000001A 0x00000003 0x00000000 0x00000000 0x00000000
0x8000001B 0x000000FF 0x00000000 0x00000000 0x00000000
0x8000001C 0x00000000 0x80032013 0x00010200 0x8000000F
0x8000001D 0x00000121 0x00C0003F 0x0000003F 0x00000000
0x8000001D 0x00004122 0x0040003F 0x000001FF 0x00000000
0x8000001D 0x00004143 0x03C0003F 0x000007FF 0x00000001
0x8000001D 0x0000C163 0x07C0003F 0x000007FF 0x00000001
0x8000001E 0x00000000 0x00000100 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00900
MSR 0xC0010114 0x00000000 0x00000018
MSR 0xC0010061 0x00000000 0x00000054
MSR 0xC0010062 0x00000000 0x00000000
MSR 0xC0010063 0x00000000 0x00000004
MSR 0xC0010064 0x800001D5 0x00001617
MSR 0xC0010065 0x800001D5 0x00001616
MSR 0xC0010066 0x8000019A 0x00001815
MSR 0xC0010067 0x80000184 0x00002412
MSR 0xC0010068 0x80000165 0x00003C0A
MSR 0xC0010058 0x00000000 0xE0000001
MSR 0xC0010015 0x00000000 0x01000010
MSR 0xC001001F 0x00404000 0x00810008
MSR 0xC0010071 0x05800006 0x30055002
MSR 0xC0010070 0x00000000 0x30055002
CPU Thread 1
APIC ID 1
Topology Processor ID 0, Core ID 1, Thread ID 0
CPUID
0x00000001 0x00600F12 0x01040800 0x1E98220B 0x178BFBFF
0x80000001 0x00600F12 0x10000000 0x01C9BFFF 0x2FD3FBFF
0x8000001E 0x00000001 0x00000100 0x00000000 0x00000000
MSR 0x0000001B 0x00000000 0xFEE00800
CPU Thread 2
APIC ID 3
Topology Processor ID 0, Core ID 3, Thread ID 0
CPUID
0x00000001 0x00600F12 0x03040800 0x1E98220B 0x178BFBFF
0x8000001E 0x00000002 0x00000101 0x00000000 0x00000000
MSR 0xC0010061 0x00000000 0x00000050
MSR 0xC0010063 0x00000000 0x00000000
MSR 0xC0010071 0x01000006 0x30011616
MSR 0xC0010070 0x00000000 0x30011616
CPU Thread 3
APIC ID 2
Topology Processor ID 0, Core ID 2, Thread ID 0
CPUID
0x00000001 0x00600F12 0x02040800 0x1E98220B 0x178BFBFF
0x8000001E 0x00000003 0x00000101 0x00000000 0x00000000
Graphic APIs
API D3D
API NVIDIA I/O
API NVIDIA NVAPI
Display Adapters
Display adapter 0
ID 0x1070208
Name NVIDIA GeForce GT 730
Board Manufacturer ZOTAC International Ltd.
Revision B1
Codename GK208
Core family 0xB06 (GK208)
Technology 28 nm
Memory size 4 GB
Memory type DDR3
Memory vendor Samsung
PCI device bus 1 (0x1), device 0 (0x0), function 0 (0x0)
Vendor ID 0x10DE (0x19DA)
Model ID 0x1287 (0x730B)
Revision ID 0xA1
Performance Level 0
Core clock 901.5 MHz
Memory clock 800.0 MHz
Win32_VideoController AdapterRAM = 0xFFF00000 (4293918720)
Win32_VideoController DriverVersion = 26.21.14.3200
Win32_VideoController DriverDate = 07/24/2019
Monitor 0
Model 22M33 (LG Electronics (GoldStar))
ID GSM5AAB
Serial 408NDQA9C308
Manufacturing Date Week 8, Year 2014
Size 21.7 inches
Max Resolution 1920 x 1080 @ 60 Hz
Horizontal Freq. Range 30-83 kHz
Vertical Freq. Range 56-75 Hz
Max Pixel Clock 150 MHz
Gamma Factor 2.2
ACPI
ACPI Tree
CPUID SMBus Report
Binaries
SMB device I/O = 0xB00, address 0x53, channel = 0
SMBus registers
00 92 11 0B 02 04 21 00 09 03 11 01 08 0A 00 FE 00
10 69 78 69 30 69 11 18 81 60 09 3C 3C 00 F0 83 01
20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
30 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 21 01
60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
70 00 00 00 00 00 85 02 02 00 00 00 00 00 00 56 3F
80 50 53 44 33 38 47 31 36 30 30 32 00 00 00 00 00
90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SMB device I/O = 0xB00, address 0x38, channel = 0
SMBus registers
00 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00
10 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00
20 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00
30 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00
40 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00
50 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00
60 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00
70 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00
80 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00
90 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00
A0 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00
B0 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00
C0 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00
D0 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00
E0 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00
F0 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00
Paperdoc
Glorious
Ambassador
This may not help much because I have not used HWMonitor Pro. I do notice that it reports most voltages close to nominal, BUT both 12 VDC readings are much lower than they should be. Maybe others can shed more light.
PvEdominator
241
28
When you mean by fans, what do you mean? The case fans? Or the fans that go onto the CPU Cooler? Case fans are usually on the front of the case, and on the back. And there is a fan that looks like its right on the components.
Mar 21, 2020
7
The case fans do not work. I am not sure about the CPU fan, I'll open up my tower and take a look and then let you know. Thank you both for the replies.
maikutech
1,385
12
19,965
286
Reboot the computer, go into bios, navigate to CPU/FAN specs, take a picture and bring it back here.
Also given that particular motherboard, it has a history of problems so I wouldn't be surprised to see it fail.
