Question My fans have 6 pin connectors but my motherborad only has 4 pin connectors
Dec 27, 2018
Hi,
I have just built my first pc, and it has gone quite smoothly. However the only issue i've had was with installing the fans. They have 6 pin connectors but my motherboard (aorus b450 pro) only has 4 pin. Is there any way to fix this?
Thanks
Jun 13, 2019
9
which type of fans are they nd of which brands plus if they are 6pins then their must be a hub with that which will have a 4pin plug thats u will connect to the mobo
Karadjgne
Herald
Only fans I've ever seen with 6pins are high speed server fans, like the 80mm back to back Deltas at 8000rpm.
Other than that, 6pin is more often proprietary rgb design from several years ago when really nobody had the same 2 setups.
