Here are the final specs:
Case: Phanteks Enthro Primo SE red/black
MB: Asus x99 Rampage Extreme
CPU: Intel i7-5930k
GPU: 2x Asus Poseidon GTX 980
PSU: Corsair AX 1200i
RAM: 4x4 Corsair Dominator Platinum DDR 4 2800Mhz
BOOT M.2: Samsung SM951 m.2 256GB
APP SSD: 2x Samsung 850 Pro 256GB (Raid 0)
SSD: Samsung 850 Pro 512GB
HDD: Western Digital Black 4TB
USB Hub: NZXT
DVD: Asus DVD/BR Drive
Water Cooling:
13 x Corsair SP 140 Fans
Primochill CTR 240mm Clear Phase 2 Reservoir with Swiftech D5 pump
Alphacool NexXxoS ST30 Full Copper 420mm radiator
Alphacool NexXxoS UT60 Full Copper 280mm radiator
Mayhem X1 Blood Red Concentrate
Primoflex Advanced LRT Tubing
Swiftech Apogee XL CPU block with ROG front
Customer Wiring (don't remember where I got them from)
Lots of Monsoon fittings
https://twitter.com/Brighttail/status/590997382004871169
I changed the Fluid from Red to Blue because I thought there was too much red in the case. I'm still debating on taking out the Corsair Dominator Airflow Memory Fans, but I'm waiting to get a cable that will allow me to change both of the colours to be the same. One unfortunate problem is that the window on the side panel is tinted. When it is on, it makes the fluid look like black instead of blue, so I may have to find some white LEDs and figure out positioning on them to make it all stand out properly.
What you all think?
CPU: Intel i7-5930k
USB Hub: NZXT
Water Cooling:
What you all think?
