My first build: Are all of my parts compatible?
Christiano39
I'm relatively new to computer hardware, and this will be my first build. I just wanted to double check with the experts that all of my parts are compatible. I'm just trying to get my feet wet with this one, so it's nothing special, but I want it to be easily upgradeable. Anyway, here are the parts.
Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
PSU
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182068
Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131872
GPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130910
CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113286
RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820313123
HDD
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840
Optical Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151267
Thanks for the feed back! Just one more question. Is there anything I need to get along with these things in order to build the computer or does everything I need come with the components?
You'll do find with a screw driver, some of those zip ties and a anti static band for grounding yourself to prevent yourself from being electricuted or shorting your parts
