My first build! HELP!
Cdyt7717
14
Hey guys, Im looking at building a desktop for audio recording. This is my first build so im, well, uneducated i guess, on some of this stuff, and i could use some help. First off, the case. I have been looking at getting the Cooler Master HAF 922,
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119197
But my concern is that, since Ill be recording in the same room, is that it will be loud. Does anyone have any experience with this case? Also, since this is my first time building a computer, I want to make sure that im not forgetting anything or going to buy anything that, wont work together.. Thats the last thing i was is to get this whole thing together, try and turn it on, to find out that i messed something up because of a stupid mistake. So, I was wondering if this seemed like a decent setup and if yall had any suggestions on anything that would work better with what im wanting to do.
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131837
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011
Processor: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Memory: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
Storage: http://www.newegg.com/Product/Product.aspx?Item=N82E16820239045
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148912
OS: some version of Win7 64bit
I will also need a good firewire card, which im not sure what to get yet, and I was also thinking of getting this to keep cool a little better than stock, and ive heard that its very quiet
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608018
Let me know what you guys think and if im missed anything anywhere, Id greatly appreciate any help and Thank you all for your help in advance!
I plan on adding another 8 at least, and if thats still not enough for my needs ( mostly audio recording & DAW stuff, maybe a little gaming here and there) then ill replace the 2 x2Gb with 2 more 4Gb sticks. And thanks for the recommendation! Ill look into that one, plus it looks cooler, haha, not that that really matters when its inside a case.. but still.
