My first build - HELP
tobias.er.sej
Hey Guys,
I have just finished a draft for my first build, and I could really use some expert second opinions. As said, this is my first build, and i'm a little lost, if I should change/optimize something - I would like if the price would not exceed 800 Euro ~ 950 USD.
Can I get it cheaper, and still maintain some brutal force?
Link: https://de.pcpartpicker.com/list/j6mRLD
quick swap round,dumping the ssd, gets you a 1060 3gb in there instead.
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor (€194.99 @ Amazon Deutschland)
Motherboard: MSI - B350 PC MATE ATX AM4 Motherboard (€79.90 @ Caseking)
Memory: Team - Vulcan 16GB (2 x 8GB) DDR4-2400 Memory (€154.73 @ Amazon Deutschland)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (€47.85 @ Amazon Deutschland)
Video Card: Gigabyte - GeForce GTX 1060 3GB 3GB Windforce OC Video Card (€216.99 @ Amazon Deutschland)
Case: Zalman - Z1 Neo ATX Mid Tower Case (€39.90 @ Caseking)...
doesnt make much sense mate really balancing wise
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard (€93.97 @ Amazon Deutschland)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory (€177.89 @ Mindfactory)
Storage: Crucial - MX300 275GB M.2-2280 Solid State Drive (€90.37 @ Amazon Deutschland)
Video Card: KFA2 - GeForce GTX 1050 Ti 4GB OC Video Card (€153.79 @ Mindfactory)
Other: Corsair CP-9020120-EU Alimentation Series CX450, 450W, 80 Plus Bronze (€46.37 @ Amazon Deutschland)
Total: €797.28
Generated by PCPartPicker 2017-12-05 14:30 CET+0100
Better use of your money & includes a decent case with decent preinstalled cooling
I'm going to use it for gaming - would you say this is more balanced for that?
Just glanced the Ryzen 5 1600, sounds like a f**king beast!
As stated earlier, i'm new in the PC-building game, but the soloution above, would be a good entry level PC? And will it keep up the beastmode in the years to come - I don't want to buy new parts every year...
And finally a huge amount of thx thrown in your direction!!
Edit: The compability notes said this: The motherboard M.2 slot #2 shares bandwidth with a SATA 6.0 Gb/s port. When the M.2 slot is populated, one SATA 6.0 Gb/s port is disabled. Should this be taken into account, or what?
The ryzen 1600 is still the best price to performance cpu on the market imo.
The weakest component in there is the 1050ti but on a 800 euro budget there isnt really another choice.
Could drop the ram to 8gb & get a gtx 1060 in there but in all honesty Id go with 16gb & the 1050ti,That board/ram/cpu combo is going to be good for 5 years imo easily.
The only thing youre ever gong to have to consider upgrading really is the gpu but thats something thats unavoidable 2-3 years down the line anyway.
Ive been though 5 or 6 gpu upgrades since my first gaming pc back in 2010.
You could really do with a secondary 1tb+ hard drive in there though,ssd space fills up fast & aint going to hold many games at all.
m2 slot taking up sata 6 ?? Not an issue ,still have slots 1-5 - thats room to add another 5 x sata based drives to the build.
Total: €780.73
Generated by PCPartPicker 2017-12-05 15:16 CET+0100
If i'm only to play CS:GO and PUBG - would it be enough, to swap the hdd in the above build with the Crucial - MX300 275GB M.2-2280 Solid State Drive - I don't think, that I will be in need of more than 275 GB - I have plenty of cloud space for docs, vids and so on.
