My First Build | Need Help in Graphic Cards and Motheboard
Dec 4, 2018
17
Hi,
im Building New PC.
i got very Helpful suggestion and pc build guide from my last thread.
i show it to my near Computer retailer, and he updated my configuration and suggested me something else.
My Original PC Build Config :-
CPU: AMD - Ryzen 7 2700 3.2 GHz 8-Core Processor (Item model number :- YD2700BBAFBOX) with Included Components : Processor, CPU Cooler
Motherboard: MSI - B450M PRO-M2 Micro ATX AM4 Motherboard
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory
Storage (SSD): Western Digital - Green 240 GB 2.5" Solid State Drive
Storage (HDD): Seagate - Barracuda 2 TB 3.5" 7200RPM Internal Hard Drive
Video Card: Zotac - Zotac Amp Edition Ge-force GTX 1060 6GB DDR5 PCI-e Graphics Card with Ice Storm Cooling
Power Supply : Corsair VS550 550-Watt Power Supply
Case: Cooler Master MasterBox Lite 3.1 mATX Case with Dark Mirror Front'
___________________________________________________________________________
But He Suggested me to BUY another MOBO
in Mother Board :- GIGABYTE B450 AORUS PRO WIFI (AMD Ry-zen AM4/M.2 Thermal Guard with Onboard WIFI/HDMI/DVI/USB 3.1 Gen 2/DDR4/ATX/Motherboard)
https://www.amazon.com/GIGABYTE-B450-AORUS-PRO-WIFI/dp/B07FW85VFT
so whats the Difference between this two MOBO Gigabyte b450 aorus pro WiFi and msi b450m pro-m2 ??
does this gigabyte b450 pro wifi comes with in-built WIFI and bluetooth??
also he suggested me to buy Gigabyte GTX 1060 6gb Graphic Card :-
https://www.amazon.in/Gigabyte-Geforce-Gtx-Video-Card/dp/B01JNUO6BG
So whats Difference between Zotac amp edition gtx 1060 6gb ddr5 and Gigabyte GTX 1060 6gb Graphic Card??
Does all the Components fit in mine Cabinet perfectly??
https://www.amazon.in/Cooler-Master-MasterBox-Mirror-Front/dp/B071GYMHKL/ref=cm_cr_arp_d_product_top?ie=UTF8
which PSU should i buy??Suggest me please.
https://www.amazon.in/Gigabyte-Geforce-Gtx-Video-Card/dp/B01JNUO6BG?tag=georiot-in-default-21&ascsubtag=tomshardware-3719477077724563914-21
and no worry to sped on case.
i want this case link given below.
does this case compitable to my currunt configuration??
I want to know the above too ^
My Spec :-
AMD Ryzen 7 2700 3.2 GHz 8-Core Processor
Gigabyte B450 Aorus pro wifi
Samsung evo or WD green SSD 240GB
Seagate baracuda 2TB HDD
Zotac or Gigabyte 1060 6GB double fan
550W PSU
Corsair 16GB Ram
can you please suggest me a good and transparant case that around 3500 - 3800 INR(Indian Ruppes.) - in Dollor $48 to 54$.
i want to add 2 or 1 RGB fan in front and add one back side.
Amd r7 2700 cooler comes with Light fan., so it would be looking good pc.
yoo.....i Found the case!
tell me is it perfact or not?
Corsair - SPEC-01 ATX Mid Tower Case
https://www.amazon.in/Corsair-Carbide-CC-9011050-WW-Mid-Tower-Gaming/dp/B00I6BJATW
Go with x470 for better power delivery to the 2700.
Purchase larger SSD for system drive now, then purchase the HDD later for additional storage.
CPU: AMD - Ryzen 7 2700 3.2 GHz 8-Core Processor (₹26479.00 @ Amazon India)
Motherboard: MSI - X470 GAMING PRO ATX AM4 Motherboard (₹14804.27 @ Amazon India)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory (₹13760.87 @ Amazon India)
Storage: Crucial - MX500 500 GB 2.5" Solid State Drive (₹7250.87 @ Amazon India)
Video Card: Zotac - GeForce GTX 1060 6GB 6 GB AMP! Edition Video Card (₹25199.00 @ Amazon India)
Case: Fractal Design - Focus G (Black) ATX Mid Tower Case (₹13000.00 @ Amazon India)
Power Supply: SeaSonic - S12II 620 W 80+ Bronze Certified ATX Power Supply (₹7100.00 @ Amazon India)
Case Fan: Fractal Design - FD-FAN-SSLL-120-WT 41.8 CFM 120mm Fan
Total: ₹107594.01
Generated by PCPartPicker 2018-12-27 18:52 IST+0530
well, i dont want to sped that too much on case.
and budget is going too far,
well , great configuration for future.
but can you tell me Corsair - SPEC-01 ATX Mid Tower Case is compitable for my currunt configuration which i mentioned.??
and yaah one thing more, does gigabyte b450 aorus pro wifi which i mentioned, does it support water cooling?
in future i will add, corsair or cooler master double fan rgb cooler.so
also i will gaming or do my work on pc atleast 8 hours and more, so.
will it fine without liquide cooler for now?? does amd fan give good cooling??
The spec 01 is ok for your components ,it does not support a 240mm watercooled radiator though.
The 2700 stock cooler is decent if you have reasonable ambient temps & decent case airflow.
Hot India!
The City i Leave in - Winter - 10 degree celsius to 28 degree celsius
- Summer - 36 degree celsius to 48 degree celsius (Sometimes 50 degree celsius)
- Monson - 25 degree celsius to 34 degree celsius
so im buying Corsair cx550 or the one you suggetsed.
when i meet retailer, he suggested me MSI mobo.
he told me to use MSI board for good perfomance-
Here this MSI Board :- MSI B450 Gaming pro carbon ac.
now i again confused in MOBO, which board will be long lasting and give perfomance,
Gigabyte b450 aorus pro or this MSI board.???
