Approximate Purchase Date: August 1
Budget Range: 950,000 KRW (Approx 850)
System Usage from Most to Least Important: Gaming, surfing the internet, watching movies)
Are you buying a monitor: Yes
Parts to Upgrade: Everything
Do you need to buy OS:No
Preferred Website(s) for Parts: www.danawa.com
Parts Preferences: AMD cpu + gpu
Overclocking: Maybe (I probably will, but not aggressively)
SLI or Crossfire: Maybe in the future
Monitor Resolution: 1920x1080
Why Are You Upgrading: 5 year old laptop, no gaming machine and a bit of money to burn!
ASUS M5A97 LE R2.0 Motherboard - 90,000 KRW
AMD FX 8350 CPU -197,000 KRW
Sapphire Radeon HD 7850 OC D5 2 GB Dual X - 209,000 KRW
Sandisk Ultra Plus (128GB) - 104,000 KRW
G.SKILL DDR3 8G PC3-12800 CL9 RIPJAWS XL (4Gx2) - 96,000 KW
PSU - Antec VP550P V2 - 62,000
Case - GMC V1000 45,000 KRW
Cooler - Coolermaster Hyper 212 EVO - 35, 000 KRW
Used Monitor + Keyboar and Mouse - Approximately 130,000 KRW
1 TB WD drive (from old setup)
Total = 968,000 KRW
How does this look? Is it possible to get a cheaper PSU and cooler?
Also, I can save about 15,000 with an VTX 7850, but not so sure bout this brand.
Theres also a XFX 7850 which saves me 8,000. Does anyone have experience with these makes?
XFX Model
VTX Model
It may seem like I'm quibbling over a small amount, but that small amount will appease the wife. If I could get down to 900,000 it would be great!
Suggestions? Thanks!
Total = 968,000 KRW
XFX Model
VTX Model
