Hey,
Basically, I'm currently drawing up a spec list for my first build. It's going to be Sandy Bridge, with i5-2500K CPU, but I'm stuck as to how to choose a motherboard
I want to have 1600Mhz RAM, which I realise not many boards support without OC, and I will be running a 6850/6870 GPU, which I'm hoping to upgrade to Crossfire in the future 😀 (so I need a couple of PCIe x16 running @ > x8)
My budget for the entire build is about £800, including the monitor etc, so I'm guessing I'll spend £100-120 on a mobo.
So far I've found what I think are a couple of pretty decent motherboards:
Asrock P67 EXTREME4 V3 1155 Socket 7.1 Channel HD Audio ATX Motherboard
http://www.ebuyer.com/product/261255
Gigabyte GA-P67X-UD3 P67 Socket 1155 7.1 Channel HD Audio ATX Motherboard
http://www.ebuyer.com/product/265918
What do you guys think? Which of these should I go for, or are there any other better motherboards for a similar price?
Also, is £100-120 an ok budget for a motherboard if I am going to spend £800 on the whole build?
Thanks in advance 😀 ,
Junaid
P.S. *PLEASE* nobody start lecturing me about not having used a specific format for my post...
Junaid
