Hey everyone,
Ive been debating building my own desktop for the past several months and about 3 weeks ago I deceided to start down the road to selecting the various components in order to successfully and hopefully build my own PC. This pc will be used for a variety of tasks including gaming, watching/recording tv (USB tv tuner), burning DVD's, and running intensive apps such as solidworks and autocad. Below is my current build that ive come up with. Since i am very new to this I am very open to any and all comments. I am mainly wanting to verify that each of these components are compatible with one another and any other suggestions that I should know about before purchasing the parts!
NOTE: I have two builds that I am currently contemplating. The first one I came up with on my own and the second one was recommended to me by a friend. Both are open to any changes that anyone suggests. Which one do you think I should go with?
APPROXIMATE PURCHASE DATE: 2-4 weeks
BUDGET RANGE: 800$ US
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Multitasking, gaming, CAD, Burning DVD's
PARTS NOT REQUIRED: Keyboard, Mouse, Monitor, Speakers, OS
PREFERRED WEBSITE(S) FOR PARTS: newegg.com, but I am available to buy from the cheapest vendor out there!
PARTS PREFERENCES: Does not Matter
OVERCLOCKING: Probably not
MONITOR RESOLUTION: 1680x1050
BUILD NUMBER 1:
MOTHERBOARD:
MSI P45 Neo3-FR Intel P45 Core 2 Extreme/Core 2 Duo/Core 2 Quad Socket 775 1600 MHz PC2-8500 DDR2-1066 ATX Motherboard (98.99$)
http://www.amazon.com/MSI-Neo3-FR-PC2-8500-DDR2-1066-Motherboard/dp/B001B8KE5G
CPU:
Intel Core 2 Duo E8500 Wolfdale 3.16GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor (189.99$)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115036
GRAPHICS CARD
SAPPHIRE 100259-1GL Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card (199.99$)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102801
PSU
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply(74.49$)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
HARDDRIVE
Western Digital Caviar SE16 WD2500AAKS 250GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive (54.99$)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136161
RAM
Patriot Viper 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory (33.99$)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220335
DVD-DRIVE
SAMSUNG Black 22X DVD+R 8X DVD+RW 16X DVD+R DL 22X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 22X DVD Burner (24.99$)
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151171&Tpk=Samsung%20SH-S223F
CASE
Antec Three Hundred Black Steel ATX Mid Tower Computer Case (58.99$)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042&Tpk=Antec%20Three%20Hundred
TOTAL COST: 736.92$
BUILD NUMBER 2:
COOLER MASTER RC-690-KKN1-GP Black SECC/ ABS ATX Mid Tower Computer Case $75
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
ASUS M4A78T-E AM3 AMD 790GX HDMI ATX AMD Motherboard $140
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131366
MSI N260GTX-T2D896-OCv4 GeForce GTX 260 896MB 448-bit DDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card $165 ($145 after MIR)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127430
PC Power & Cooling Silencer PPCS500 500W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Power Supply $70 ($60 after MIR)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817703015
AMD Phenom II X4 810 2.6GHz 4 x 512KB L2 Cache 4MB L3 Cache Socket AM3 95W Quad-Core Processor $170
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103650
OCZ Platinum 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory $64
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227297
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive $75
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
LG Black 22X DVD Burner $24
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136152
TOTAL = $782.92 - Rebates + S&H
Like I said earlier..i am quite new to this and want to hopefully have a successful and positive build that will give me a desktop that will last for some time. i am open to all suggestions and comments.
thanks,
Austin
BUILD NUMBER 1:
MOTHERBOARD:
CPU:
GRAPHICS CARD
PSU
HARDDRIVE
RAM
DVD-DRIVE
CASE
TOTAL COST: 736.92$
BUILD NUMBER 2:
thanks,
Austin
