My First Build using Ryzen Memory ?
headsplitta90
8
This is my first build I've always been on console and played mildly on a non gaming pc, but never built one before..
Im gonna be using the Ryzen 5 1600 CPU and plan on OC at some point, my main question is will i have problems running these Gskill ripjaws @ 3200MHZ??
heres my exact build, any imput would be nice
Thanks in advance
https://pcpartpicker.com/list/Fr7HwV
Not on the QVL list, but ripsaw V is very likely to run 3200. My other model ripsaw V is not on my MSI B350M gaming pro QVL, but runs @ 3200 now. I would say not guaranteed, but very likely. Even if now the mb does not support 3200 with the ram, future bios updates may help.
yeah I noticed it wasnt on the QVL so I was curious if anyway else has a similar set up.. so if i get those and it doesnt support I should be able to run them at a lower MHZ?
PSU is he major drawback, CX is not very good. My edits with similar price:
CPU: AMD - Ryzen 5 1600 3.2GHz 6-Core Processor ($193.44 @ OutletPC)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard ($56.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory ($154.99 @ Newegg)
Storage: SK hynix - SL308 250GB 2.5" Solid State Drive ($78.89 @ OutletPC)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($41.77 @ OutletPC)
Video Card: Asus - GeForce GTX 1060 6GB 6GB Dual Video Card ($279.99 @ SuperBiiz)
Case: Fractal Design - Focus G (Black) ATX Mid Tower Case ($49.99 @ Amazon)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply ($49.99 @ Amazon)
Total: $906.04
Generated by PCPartPicker 2017-11-16 21:08 EST-0500
i didnt see those..thanks for pointing that out
I like it.. will this perform well? and also is that asrock MB better than the gigabyte? are they good with bio updates?..sorry im new as I stated above and just wanna make a solid build that i can learn off of/upgrade.
so the gigabyte is a solid board also ? I live about 10 min from a Microcenter and I can get the Ryzen 5 1600 with the gigabyte MB for $229 + $20 MIB. I was gonna buy that there and order the restof the parts online since there cheaper
$224.98 + $20 MIB ($204 final) looks like I'm going with that haha for some reason that board wasn't showing up that I could bundle and get the price cut..Sweet!
So I take it theres not a huge difference between the Asus GTX 1060 and The Evga GTX 1060 besides little bit of speed? would that even make a huge difference
i agree i like the theme and theres virtually no perform difference between the two according to gpu boss. besides the two fans for oc
i appreciate your import im pretty sure its time to open up the wallet now :lol:
