My first build- Will it work
bailoon
5
I want to know before i start buying everything that these parts are compatible and if i have missed something that might be important. I have went on pcpartspicker.com and put my components in and some don't register so i dnt know if they are compatible or are lacking something. This is also my first time building so if u have any comments or concerns let me know.
My parts list:
CPU- Intel Core i5-7600 3.5GHz Quad-Core Processor
CPU cooler- stock that comes with cpu, i will buy a better later
Motherboard- ASUS B150-​PRO D3 LGA​ 1151 Inte​l B150 HDM​I SATA 6Gb​/s USB 3.0​ ATX Intel​
Ram- Crucial - Ballistix Sport 16GB (2 x 8GB) DDR3-1600
Hard drive- Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard drive
SSD- Kingston A400 2.5" 120GB SATA III TLC Internal SSD
Video Card- Asus - GeForce GTX 1060 6GB or 3gb dual video card, not sure whether to
Case tower- Thermaltak​e Versa N2​4 Black AT​X Mid Towe​r Gaming C​omputer Ca​se with Po​wer
Supply​ Cover CA-​1G1-00M1WN​-00
Power supply- EVGA - 500W 80+ Certified ATX
Links-
CPU- https://www.amazon.com/dp/B01MYTYSMK/?tag=pcpapi-20
Motherboard- https://www.newegg.com/Product/Product.aspx?Item=N82E16813132697R
Ram- Crucial - https://www.newegg.com/Product/Product.aspx?
Item=N82E16820148545&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-
PCPartPicker,%20LLC-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
Hard drive- https://www.amazon.com/dp/B0088PUEPK/?tag=pcpapi-20
SSD- https://www.newegg.com/Product/Product.aspx?Item=N82E16820242399&nm_mc=AFC-
C8Junction&cm_mmc=AFC-C8Junction-PCPartPicker,%20LLC-_-na-_-na-_-
Video Card-https://www.amazon.com/dp/B01JHQT1SE/ref=twister_B01KJGWHIM?
_encoding=UTF8&th=1
Case tower- https://www.amazon.com/Thermaltake-Gaming-Computer-Supply-CA-1G1-00M1WN-
00/dp/B01FG9XS5I/ref=sr_1_6?s=pc&ie=UTF8&qid=1499112580&sr=1-
6&keywords=desktop%2Bcase&refinements=p_n_feature_keywords_four_browse-
bin%3A6570423011&th=1
Power supply- https://www.amazon.com/dp/B00H33SFJU/?tag=pcpapi-20
Some of your links don't work.
B250 chipset motherboard. You're going to need to perform a BIOS update if you plan to run a B150 motherboard on the Kabylake processor. Also, why not just more to DDR4? Might it be possible for you to pass on your budget and your location? We could perhaps source a better list of parts for you.
