A Ajl1309 Honorable Jan 1, 2014 18 0 10,520 Jan 1, 2014 #1 as the title says this will be my first build and i would like to know if it's going to work well. http://gyazo.com/1169e229eb459b9c7820ed28165392b7
Solution lucasz Jan 1, 2014 That motherboard is good, but you should get this power supply: http://www.scan.co.uk/products/750w-xfx-p1-750s-nlb9-85-eff-80-plus-bronze-sli-crossfire-eps-12v-quiet-fan-atx
lucasz Honorable May 18, 2013 1,406 0 11,660 Jan 1, 2014 #2 Get a better power supply and a z87 motherboard Upvote 0 Downvote
lucasz Honorable May 18, 2013 1,406 0 11,660 Jan 1, 2014 #3 I recommend the AsRock Extreme4 Z87 motherboard. A good power supply would be the XFX ProSeries 750w Upvote 0 Downvote
A Ajl1309 Honorable Jan 1, 2014 18 0 10,520 Jan 1, 2014 #4 thanks and would these be better choices then? http://www.scan.co.uk/products/msi-z87-g43-gaming-intel-z87-s-1150-ddr3-sata-iii-6gb-s-raid-pcie-30-(x16)-d-sub-dvi-d-hdmi-atx http://www.scan.co.uk/products/750w-corsair-builder-series-cx-85-eff-80-plus-bronze-sli-crossfire-eps-12v-quiet-fan-atx-v231-psu Upvote 0 Downvote
lucasz Honorable May 18, 2013 1,406 0 11,660 Jan 1, 2014 Solution #5 That motherboard is good, but you should get this power supply: http://www.scan.co.uk/products/750w-xfx-p1-750s-nlb9-85-eff-80-plus-bronze-sli-crossfire-eps-12v-quiet-fan-atx Upvote 0 Downvote Solution
A Ajl1309 Honorable Jan 1, 2014 18 0 10,520 Jan 1, 2014 #6 ok thanks and do you know if the case is going to be alright with the parts chosen? Upvote 0 Downvote
lucasz Honorable May 18, 2013 1,406 0 11,660 Jan 1, 2014 #7 Yep it'll be good. I built a buddy's pc with that case. It's nice Upvote 0 Downvote
A Ajl1309 Honorable Jan 1, 2014 18 0 10,520 Jan 1, 2014 #8 thanks a lot man, much appreciated. Upvote 0 Downvote
