My First Build
mattmcd123
4
Just looking for some advice on my first go at a build for gaming. Looking to play modern games at high without lag, and move down to medium in the next few years if I need to. Just checking if this seems right, and if I can cut costs anywhere without losing out on much performance.
Mobo - MSI Z87-G45 Gaming ATX LGA1150
CPU - i5 4670k 3.4GHz Quad Core Processor
Memory - Corsair Vengeance 8GB (2x4GB) DDR3-1600
Storage SSD - Kingston SSDNow V300 Series 120GB 2.5" SSD
HDD - Seagate Barracuda 1TB 3.5" 7200RPM
GPU - Gigabyte GeForce GTX 670 2GB
Case - Corsair 200R ATX Mid Tower Case
Power Supply - Corsair CX 600W 80 PLUS Bronze Certified ATX12V
Optical Drive - LG GH24NS95 DVD/CD Writer
Wireless Network Adapter - TP-Link TL-WN722N 802. 11b/g/n USB 2.0
Is this all compatible? Could anything else easily be downgraded without any noticeable effect on performance with my use? Is the Power Supply right?
I'd personally go for the newer, GTX 770 instead of the 670.
This is about £100 over the budget I had set out with (budget was £600-700 and this is almost £800), so I'm looking to make it a bit cheaper for now with an eye to upgrade when I can. I will be overclocking.
You will not want to skimp on a quality motherboard and powersupply if you're overclocking!
