My First Build
Grozzly
6
Hard drive-WD Blue 1 TB
case-Bitfenix Shadow or BitFenix Shinobi /w Window
MOBO-ASUS M5A97 R2.0
Moniter-Asus VE247H
ram-8GB Corsair Vengeance
core-AMD FX-6300
PSU-Corsair 600 watt 80plus bronze cert
GPU-EVGA GTX 760 SC/w ACX cooler
System-Microsoft windows 8.1 64 bit (SB-Version)
Hello, that is the parts i have chosen, i am completely new to this so if there can be any improvements on price and performance my limit is 900 euro and if everything works together your input would be great thanks :)
you should be fine with this built...but if you may, i would suggest you go for fx 8320/8350
i hope that ram is actually an 8gb kit and not a single module (kits are better)
yes its kit 8350 is a bit out of my price range i could stretch for 8320 but is it worth it?
