Hi guys n gals. I have upgraded my current pc in the past a few times and am amazed how much things have changed since then. I know I want to go with an i5-6500 gtx1060 build. Not for sure about company reputations. Usually just play mmo and a couple fps games. I would like to keep it under 900 usd. I will not be overclocking, play in 1080, and have all my peripherals. I have taken a few ideas from other builds. I might throw in a ssd later down the road but not yet. I just had carpal tunnel surgery so I thought this would be a great time to get it done. Need to know if everything looks ok, if there's anything I should change, and which 1060 you would recommend going with. Your help is greatly appreciated.
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($199.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H170M-D3H Micro ATX LGA1151 Motherboard ($88.30 @ OutletPC)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2400 Memory ($66.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($47.49 @ OutletPC)
Case: Thermaltake Commander G41 ATX Mid Tower Case ($39.99 @ Newegg)
Power Supply: EVGA SuperNOVA GS 550W 80+ Gold Certified Fully-Modular ATX Power Supply ($72.98 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($16.88 @ OutletPC)
Operating System: Microsoft Windows 10 Home OEM 64-bit ($83.89 @ OutletPC)
Total: $616.51
Generated by PCPartPicker 2016-07-25 11:54 EDT-0400
Total: $616.51
