My First Build
Feb 7, 2019
I have been saving my pennies and have enough money now to build myself a gaming rig. So I have been busy designing up a system that will be more then powerful enough for most games but also to stick to a limited budget. I kinda like what I have here but as it's my first build I don't want to pull the trigger on buying everything unless I'm sure I haven't made a mistake somewhere. My main concern right now is that the M.2 will fit as I have seen other similar builds with the M.2 but also the motherboard website said something about compatability only with 7th Generation Athalon so I don't know if I can fit that or not.
Basically I could just do with a little advise just to make sure I'm good to finally buy everything and get building.
https://uk.pcpartpicker.com/user/deathpain/saved/twc8YJ
Solid build, good parts and the M.2 will work fine with that build but I would probably just stick with the 660P M.2 for now for the OS & games then save up for a larger HDD for storage, dump the ADATA.
EDIT: Changed SSD & Case fan (You'll want 120mm instead of 80mm for exhaust in the back).
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor (£144.95 @ AWD-IT)
Motherboard: Gigabyte - B450M DS3H Micro ATX AM4 Motherboard (£64.94 @ AWD-IT)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory (£97.87 @ Box Limited)
Storage: Intel - 660p Series 1 TB M.2-2280 Solid State Drive (£106.23 @ Ebuyer)
Video Card: MSI - Radeon RX 580 8 GB ARMOR OC Video Card (£195.98 @ CCL Computers)
Case: Fractal Design - Focus G (Black) ATX Mid Tower Case (£45.98 @ Novatech)
Power Supply: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply (£63.83 @ Amazon UK)
Case Fan: be quiet! - Pure Wings 2 120 PWM 87 CFM 120mm Fan (£9.12 @ More Computers)
Monitor: AOC - G2260VWQ6 21.5" 1920x1080 75 Hz Monitor (£84.96 @ Amazon UK)
Other: Anidees Extended Computer Magnetic LED Strip (£19.90)
Total: £1003.68
Generated by PCPartPicker 2019-02-07 18:30 GMT+0000
