My first custom built
ACETB2010
11
hello huys this is my custom built please tell me how is it
processor - intel 2nd gen core i7 2600 sandy bridge
motherboard - p8z68-v-pro
graphics- gtx 570 x 3
ram - 4gb x 3
sound card - any worth 1300
wireless card - any worth 2000
power supply - corsair ax1200 gold
pc case - any worth 15000(still looking)
monitor- any 3d monitor woth 15000 with 2ms response time(still loking)
please recommend for things with still looking
thanks
CPU: i7 2600k i hope for overclocking and this budget
CPU cooler: Some nice air cooler, Cooler Master Hyper 212+, Scythe Mugen3, Noctua NH-D14
graphics: for tri-SLI you will need to look at some hefty boards so might consider dual GTX580 instead
Mobo: Asrock Z68 Extreme 7 - Asus Maximus IV Extreme-Z for the tri-SLI's
Case: Cooler Master HAX 932 or 942 are pretty good for something producing this much heat
Monitor: Not too many 3D capable monitors out there, asus has something
ram - 4gb x 3
thanks
are you indian? please tell us in USDs i am canadian BTW.
first of all 2600 is complete waste for gaming.2500k is the best.for sandybridges go with k versions.
mobo is okay.you may look for gene3 mobos.
4gbx3 is not compatible with sandy bridge cpus. go for 8 gb 1600 ram(12 gb is super over kill)
sound card is not required unless you have $300 speakers.
why do you need such a super costly PSU?3X570 is a super shitty choice instead go for 2x580 msi lightning xtreme version.a coolermaster silent pro 1000w is more than enough for 3x580s.
you dont need any 15000inr or 333 usds case.HAF X,thermaltake armour +(i own it),NXZT phantom,azza hurricane 2000,antec 1200 v3,Dark fleet 85 are fantastic cases.
samsung 27 inch 3d monitor is only $600 you dont need 600+
please give us more details.budget,date of purchase etc.
there is a guy rohit008 something.he is indian and he may also help you.
yes i am an indian and no sound card got it 8gb ram ok now can you rate my config on a scae of 1 to 10 thanks please rate and i am going to use hp 3d monitor and the following case
corsair obsidian series 800D cc800dw
please rate my config and gtx 580 ain't available anywhere i go
Explaining your point is a tad easy , its just that videocard prices are high as hell here :fou:
Considering I had to shed US$270 for the ASUS ENGTX460 TOP some four days back , its a no brainer equation when it comes to the enthusiast segment . And yes , our computer vendors suck to the core .... :cry:
Hey, You can get the GTX 580 lots of places in india. I have friends who have bought components for mighty setups and I am myself in the process of getting one done.
Do check out online sellers like www.bitfang.com or www.theitdepot.com orwww.techshop.in
These guys are reliable though their prices tend to fall/rise a bit.
Also try going to local stores if any, in your area or nearby.
