Right, so this is what I have so far and it is £1000 exactly.
http://uk.pcpartpicker.com/p/4VZs3C
At first I was going to get i7-4790k & z97 mob, but for that I would have buy DDR3 RAM too. In the future, DDR4 is the way forward so if I want to upgrade then I would have to replace all of my RAM too so I went with Skylake.
As I was picking the components for this build, what I had in my mind was "Would I be able to transfer this component over to new build". From my research I think I should be able to transfer these parts onto the new build:
PSU - Good quality and 750W should be plenty.
RAM - DDR4 is the future.
CASE - Decent, should be able to keep it.
HDD - SSD, should be able to keep.
I might upgrade to the new Samsung 950 Pro NVMe M.2 1TB drive in the future. Asus z170 pro gaming does have a M.2 slot but someone said something along the lines of cpu has 16 lanes which will be used by GPU and nothing will be left for the M.2 drive ... so I am a little confused, will it work?
This basically leaves CPU, MOBO, GPU as the main upgrade components. They are the ones I will want to change in the future anyways. Am I right with everything in my thinking? Do you think this is a good build would you change anything?
