Hello,
So I'm building my first ever PC for gaming ( I'v had a few pre-built that wasn't that impressive). I have always used xbox and PS but thought as I finally can afford to spend some money I would build my own PC.
So the parts I have "decided" on (When I say decided I mean I think they sounded good but I'm as said before a beginner at this) are mostly from tomshardware recommendations and it looks like this right now.
By the way, when i say $1500-2000 i'd rather stay in the lower end of that but I'm unsure what the actual price would be as some components are a lot cheaper where I live and other more expensive than the USA.
GPU: MSI GeForce GTX 970 Gaming HDMI DP 2xDVI 4GB
CPU: Intel Core i7-4790K
Ram: Corsair Vengeance 16GB (2x8GB) DDR3 1600MHz
Motherboard: I have no clue, there are a few like MSI Z97 Gaming 5 and ASUS Z97-PRO (wi-fi)
but I don't really know what I need for what I'm buying. I should mention that It's highly likely that I will buy another graphics card when it drops some in price
chassi: Corsair Obsidian 750D
fans: 3 extra Corsair Air Series AF140 25mm (3 fans come with chassi).
CPU fan: Noctua NH-D15
Memory: Seagate SSHD Desktop 2TB 7200RPM/64mb/8Gb 3,5" ST2000DX001
Power: Corsair CX750M 750W
Monitor: not sure here either, though it will be a 1080p one
Approximate Purchase Date: within 1-2 weeks
Budget Range: $1500-2000 i'd rather stay in the lower end of that but I'm unsure what the actual price would be as some components are a lot cheaper where I live and other more expensive than the USA.
System Usage from Most to Least Important: Gaming > watching videos (prob what I will use it for)
Parts Not Required:
Preferred Website(s) for Parts: They are sadly all in Swedish but I don't mind other links for reference (otherwise I will mostly use http://www.webhallen.com/se-sv/ if you wanna give it a try)
Country: Sweden
Parts Preferences: Known brands
Overclocking:
SLI or Crossfire: No clue
Monitor Resolution: 1080p
Additional Comments: Thanks in advance for any help
Parts Not Required:
Country: Sweden
Overclocking:
