My first gaming pc build ever.Pls help
Sep 19, 2018
Hello everybody 1th time on this site so i m intrested if someone can help me :)
my build list is currently this:- Asus gtx 1060 strix 6gb gpu
-asus strix z-370h gaming motherboard
-psu coolermaster masterwatt 650watt
-cpu I5 8600k 3.6ghz
-16gb ram ripjaws v series 2133mhz
-cpu cooler arctic freezer
Wd blue 1tb hdd 7200rpm
Ssd nand 120gb
and i still dont know what case should i take, help me with this if something is not good pls say.Thank you. :)
theRTT
388
4
4,865
41
Do you want a case with window? Or not?
I'd go for the NZXT h500 for a great look and great cable management. But there are many, many cases that you can buy, so what do you want from a case?
Also, are you planning to overclock your cpu? If not, you can save some money by buying the Intel Core i5-8400 (non k!) or the i5-8600. The non k cpu's are unable to overclock, but cheaper.
And buy a motherboard with a b360 chipset. Those mobo's are most of the time cheaper.
D JAY Cva
152
28
get an 256 SSD instead 120 ... 120 is too small for gamers rig , as for case ,, what kind you have in mind .. you need to consider the space you have in your room or gaming desk ..and your budget too ,,
theRTT
388
4
4,865
41
tas_kuris
Commendable
Oct 11, 2016
48
dont know where you get that info, but its not true, all 8th gen i5's are 6 core, especialy the one with a K.
other than that, i would agree, if you dont plan to oc than you dont need a K procesor.
theRTT
388
4
4,865
41
You're right, I read the info wrongly. I thought he was talking about the i5 7600k instead of the 8600k. I'll edit my post. Thanks.
