my first gaming pc please help
theholysniper30
hey guys this is my first gaming pc build and was wondering if its good/worth $950
CARE1: Professional Wiring for All WIRING Inside The System Chassis - Minimize Cable Exposure, Maximize Airflow in Your System
CAS: Apevia X-Cruiser 3 w/ USB 3.0, Temperature & Fan Control, Side Panel Window (Black Color with Red LED)
CASUPGRADE: RGB Multi-Color (16 color) LED interior light strip with Remote Controller
CD: 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLACK COLOR)
CD2: None
COOLANT: Standard Coolant
CPU: AMD FX-8320 3.50 GHz Eight-Core AM3+ CPU 8MB L2 Cache & Turbo Core Technology
CS_FAN: Maximum 120MM Color Case Cooling Fans for your selected case (Red Color)
DOCKINGSTATION: None
ENGRAVING: Skull Design
FA_HDD: None
FAN: Asetek 550LC 120mm Liquid CPU Cooling System w/ Copper Cold Plate - Extreme Cooling Performance (Single Standard 120MM Fan)
FLASHMEDIA: None
FREEBIE_TB: None
GLASSES: None
HDD: 2TB (2TBx1) SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD (Single Drive)
HDD2: None
HEADSET: None
HS_HANGER: None
IUSB: Built-in USB 2.0 Ports
KEYBOARD: None
MEMORY: 8GB (4GBx2) DDR3/2133MHz Dual Channel Memory (ADATA XPG V3)
MONITOR: None
MOPAD: None
MOTHERBOARD: GIGABYTE 970A-DS3P AMD 970 ATX w/ Ultra Durable 4 Classic, On/Off Charge, GbLAN, 2 PCIe x16, 3 PCIe x1, 2 PCI
MOUSE: AZZA Optical 1600dpi Gaming Mouse with Weight Adjustable Cartridge
NETWORK: Onboard Gigabit LAN Network
NOISEREDUCE1: Power Supply Gasket [+5]
NOISEREDUCE2: Anti-Vibration Fan Mounts
OS: Windows 8.1
OVERCLOCK: Pro OC (Performance Overclock 10% or more)
POWERSUPPLY: 600 Watts - Standard 80 Plus Certified Power Supply - SLI/CrossFireX Ready
RUSH: Standard Process Time: Ship within 8 Business Day
SERVICE: STANDARD WARRANTY: 3-YEAR [3 Year Labor, 1 Year Parts] LIMITED WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
SOFT1: McAfee AntiVirus Plus
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
SPEAKERS: None
TEMP: None
TVRC: None
USBFLASH: None
USBHD: None
USBX: None
VIDEO: AMD Radeon R9 280 3GB GDDR5 PCIe 3.0 x16 Video Card (Single Card)
I would say no. You could build a better system, for the same cost.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor ($179.49 @ SuperBiiz)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard ($71.99 @ SuperBiiz)
Memory: Team Xtreem Dark Series 8GB (2 x 4GB) DDR3-1600 Memory ($54.99 @ Newegg)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($71.99 @ NCIX US)
Video Card: Zotac GeForce GTX 970 4GB Video Card ($309.99 @ Amazon)
Case: Enermax OSTROG ATX Mid Tower Case ($43.99 @ SuperBiiz)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($79.99 @ NCIX US)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer ($14.98 @ OutletPC)
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit) ($92.00 @ B&H)
Keyboard: Cooler Master CM Storm Devastator Gaming Bundle Wired Gaming Keyboard w/Optical Mouse ($27.89 @ OutletPC)
Total: $947.30
Generated by PCPartPicker 2015-03-02 15:36 EST-0500
